Using Arcade to display current day's data
1979
04-14-2020 06:22 AM
SarahLinn1
I have a bunch of points that are created daily via Survey123 that data is then displayed in ArcGIS Online.  In AGO I would only like to display the current day's data using Arcade.
This is what I am using and the code is correct but it only returns any day but today.
if ($feature.Date = today())
{return 'this'}
else {return 'that'}
Lil' bit of a novice so this may be obvious but what am I doing wrong?
Tags (1)
VictorCoelho
Hi Sarah,
The Today()  function return the current date with time truncated, the time could be the issue of why your survey123 date is not matching with the Today() function.
e.g. Mon Oct 24 2016 00:00:00 GMT-0700 (PDT)
SarahLinn1
I think that you are right but how do I convert it to be the same as my date field?
VictorCoelho
Check if your survey data is storing the time, you can compare both date by creating a new date making sure the time is not present.
e.g: Date(Year(Today()),Month(Today()),Day(Today()))
