Using a CSV to add Domains to Hosted Feature Layer
1745
11-05-2021 09:13 AM
JoBrigdale
I have approximately 40 hosted feature layers that I need to add a set list of 47 domain values too. I can create a new field quite quickly but adding the full list of domains manually will take ages. I have the list of domains required in a CSV file. Is there a way I can add it using the CSV file only?
I see that I can change domains via JSON but that still requires lots of manual editing. Any help or suggestions greatly appreciated. Thank you
Mmwilliams
I currently have this same issue and would love to know if anyone has found a solution.  We will have to update out large list regularly so having to do that manually is not really a realistic option.  Thanks for any suggestions to anyone may have.
