Update a CSV/hosted feature service in AGOL
5921
04-20-2020 04:55 AM
gismoe
Hi there,
i want to upload a CSV to AGOL and then later on i have to update this file.
Publishing the file works. A hosted feature service is created.
But i have to update the file every day. Either a fully upload or an append will do the job. The id mustn't change, because the data is used in a dashboard.
My script doesn't work. The update returns a 'TRUE' but the data isn't changed.
Any suggestions how i get the job done.
Thanks.
from arcgis.gis import GIS
username = "username"
password = "pwd"
gis = GIS("https://www.arcgis.com", username, password)
csv_file = 'd:\\file.csv'
csv_item = gis.content.add({}, csv_file)
csv_item.move('some_folder')
csv_lyr = csv_item.publish()
#   -------- works up to here ---------
ret=csv_lyr.update(data='d:\\file_update.csv')
print (ret)
IvanBrown
I have a similar situation. I have a CSV-file-based 1-table feature-service; I want to script the process of refreshing that service via new CSV files (schema is same).
A truncate() and overwrite() approach seems to work. However, I can't get a truncate() and append() approach to work.
I also need the option of just-appending; this means there is no truncate(), just appends to add new records. My code:
#Get Feature Service by Getting List of Item Objects via Query
print("Searching for feature service...")
the_services = gis.content.search(query = 'title:' + item_title + " AND " + 'id:' + item_id)
if len(the_services) != 1:
   print("Couldn't find feature service " + item_title + " in ArcGIS Online.")
   sys.exit()
#Get record count of feature service before update.
#Do this by getting "tables" property of the feature-service item;
#that property is a list of Table objects.
the_tables = the_services[0].tables
if len(the_tables) != 1:
   print("Didn't find a 1-table feature-service as expected.")
   sys.exit()
#(Capture table object.)
t = the_tables[0]
print("Before refresh, feature-service " + t.properties.name + " has " + str(t.query(return_count_only=True)) + " records.")
#Truncate.
#Do this by getting the "manager" property of the Table object, "manager" being a FeatureLayerManager object
#from the arcgis.features.managers module; FeatureLayerManager has the truncate() method.
print("Truncating...")
the_result = t.manager.truncate()
if the_result["success"] == False:
    print("Something went wrong with the truncate.")
    sys.exit()
#Get and Update CSV Table in AGO
print("Searching for CSV table in AGO...")
the_CSVs = gis.content.search(query = 'title:' + csv_item_title + " AND " + 'id:' + csv_item_id)
if len(the_CSVs) != 1:
   print("Couldn't find CSV table " + item_title + " in ArcGIS Online.")
   sys.exit()
c = the_CSVs[0]
#Update CSV Table in AGO from local CSV file
print("Updating CSV table in AGO...")
the_result = c.update(data = csv_path)
if the_result == False:
    print("Something went wrong with updating CSV table.")
    sys.exit()
#Analyze CSV Table, to get a publishParameters object (from dictionary from analyze())
print("Analyzing CSV table...")
the_analysis = gis.content.analyze(item = csv_item_id, file_type = "csv")
the_publishParameters = the_analysis["publishParameters"]
#Append to Feature Service from CSV Table
#---> HERE'S THE PROBLEM, CAN'T GET append() TO WORK! SERVICE HAS 0 RECORDS AFTER THIS!
print("Appending to feature service from CSV table...")
the_result = t.append(item_id = csv_item_id, source_info = the_publishParameters, upload_format="csv")
    print("Something went wrong with the append.")
    sys.exit()
#HOWEVER, THIS SEEMS TO WORK INSTEAD OF append()
t.container.manager.overwrite(csv_path)
CynthiaKozma
Did you ever come up with a solution to this?  I have the same problem.  I can get the csv to update if I delete it and upload it again, but this changes the id and then breaks the dashboard that is pointing to it.  I need to have the CSV update with current data that changes weekly and keep that dashboard up to date.
KarstenRank
what about updateing the feature service created from the csv file?
Overwriting feature layers | ArcGIS for Developers
CynthiaKozma
I think that might do it.  I think using the FeatureLayerCollection was the key.
from arcgis.features import FeatureLayerCollectioncities_flayer_collection = FeatureLayerCollection.fromitem(cities_item)
cities_flayer_collection.manager.overwrite(os.path.join('data', 'updating_gis_content',                               'updated_capitals_csv', 'capitals_1.csv'))
Thank you!
