Unable to Modify Feature Templates in Web Map
2753
01-23-2024 08:21 AM
JoshSaad1
Does anyone know how to manage feature templates in the new web map?  In Classic, when editing you could click the Manage button at the bottom of the edit pane to modify the feature template, but I don't see how to do that in the new web map.
I found this documentation: Manage feature templates—ArcGIS Online Help | Documentation, but the new web map is specifically omitted.
I've got a feature template where only a fraction of the features are available when editing and I'd like to add the rest but can't seem to find where to do that.
EmilyGeo
Hi @JoshSaad1
Support for managing feature templates within Map Viewer is on our future road map. In the mean time, you can use either Map Viewer Classic or the Field Maps Designer app.
To manage feature templates in the Field Maps Designer app, follow these steps:
  1. Open the Field Maps Designer app.
  2. Navigate to the layer for which you want to manage feature templates.
  3. Tap on the 'Templates' tab, which contains the list of existing templates for that layer.
  4. To create a new template, tap on the 'Add Template' button and provide the necessary information.
  5. To edit an existing template, tap on the template you want to modify and make the desired changes.
  6. To delete a template, swipe left on the template and tap on the 'Delete' option.
Hope that helps!
EmilyGeo
Hi @JoshSaad1
Hope that helps!
JoshSaad1
I'll try that.
Thank you
JeremyUmlauf
This does not allow me to update the symbology. so when I go to field maps my to values I just put in my domain show up blank and show up as other point, rather than the correct symbology.
