Unable to import shapefile (timout exceeded)
2816
08-14-2013 03:55 AM
FrancoMorelli
I'm tryin to import a shapefile of a thematic map I built on QGis.
Every time I try to upload the file Arcgis online complains : "
Error
Unable to import this shapefile. (Timeout exceeded)".
The zip file is 6 MB large.
Don't know what I'm doung wrong. Please help!
by Anonymous User
Not applicable
Can you post the shapefile zipped up so we can test it?
Andrew
DouglasBocking
Hi
I'm getting the same error... I'll link attach my zip file so you can test it
DavidParker4
I tried it and it loaded in a second or two.  geocentric datum of Australia 1194
I loaded into Map3d it was good also and exported to the attached
it works in Arc Map.  kmz is good on Google earth
suggest you retry your export from qgis
