Unable to add layer error, new
987
04-05-2024 07:48 AM
JayHodny
Hello.  I have noticed recently, when I Overwrite a feature service from Pro to ArcGIS Online, the layer will not load in the Map Viewer web map.  The layer has the same name, etc., only data in the layer has been updated.  If I choose Add, Browse, and select the updated layer it loads fine.  But now I have to rebuild the pop-up from memory (risky!).  Normally, I just push on through, rebuild the pop-up as best I can recall, and move on.  Is having to add the feature layer each time it is overwritten the normal workflow?  Or am I doing something wrong?  Thanks in advance. Jay
PS We just felt an earthquake here in Delaware a few minutes ago, it was located in north-central New Jersey.
RhettZufelt
MVP Notable Contributor
Did you check the 'Allow assignment of unique numeric IDs for sharing web layers' for that map?
If this is checked initially, then when overwriting service, it should still honor the display and popups, but only IF there were no schema changes to the dataset.
R_
