ToolTip on NearMe Widget
810
10-29-2020 05:20 AM
jaykapalczynski
Honored Contributor
There is "NearMe" widget in Web AppBuilder that allows a user to click a point on the map or geocode to an address.  This then selects all features within a given distance.  This then creates a list of results and puts them below the widget.
This works fine....The list appears to show the information configured in the Popup Title of the web map.
When you hover over one o the results it also appears to use the configured Popup Title to populate the ToolTip
I want to keep the text that is there  in the results window. BUT I want to modify whats in the ToolTip....Can this be done?
jaykapalczynski
Honored Contributor
Anyone?  Did I make sense or should I try and explain more and with screen shots.  Cheers
