Time Slider Web App- Cumulative?
2781
07-14-2016 08:20 AM
SteveCole
Honored Contributor
I want to use the time slider web app template with some data I have but I want the time animation to be cumulative like in Arcmap. Is that possible? I can't find a setting for that.
Thanks!
Steve
KellyHutchins
Esri Notable Contributor
Do you mean that it just shows one slider handle? Like this example:
http://team.maps.arcgis.com/apps/TimeAware/index.html?appid=8f1e14272f384d6896f325c7839425da
If so you can define that in the ArcGIS Online Web Map using the time slider settings. If you check the 'progressively display all data' check box you'll get one slider handle. I'll look at adding this option to the app config panel for a future release so you can overwrite the map defaults for an app.
KellyHutchins
SteveCole
Honored Contributor
My current map shows the slider as double ended, like a moving window but that linked example is exactly what I'm trying to accomplish. I tried looking for that setting but somehow missed it. I'll see if I can tweak it later today. Thanks!
