Tile cache level extent blurry
1081
06-28-2024 07:33 AM
DavidAdelsberg
Has anyone experienced an issue where you build a tile cache and share it to your Enterprise portal, add it to map viewer as map tile layer and some of the LOD have a blurry area?  I had built 21 LOD and came across some areas when I zoom in, the text and lines are blurry, but if you zoom in further, it becomes crisper/clearer.  Areas right next to the blurry areas are crisp and clear.
I'm not sure what's causing this.  Any help would be appreciated.  Please see attached pictures.
Tags (3)
