Template with options to select layers
1378
08-02-2013 08:10 AM
MaraKaminowitz
I have a map with a lot of layers and I would like users to be able to turn layers on and off, ideally in a left-hand side bar that is always shown - similar to the desktop version of ArcGIS. Is there a template that does this? I can modify parameters in javascript or python but I am not good at coding so my customization abilities are limited.
MikeMinami
Esri Notable Contributor
The basic viewer displays a Layers menu option that allows you to turn layers on and off. Most of the others don't. All templates are downloadable and can be customized. But you have to host your custom application on your own web server.
Mike
MaraKaminowitz
Can you point me in the direction of some code I could insert into the template?
MikeMinami
Sorry, the best I can do is point you here
https://developers.arcgis.com/en/javascript/
Mike
