Suggestion: Allow sharing of code via URL instead of ZIP upload
4656
06-21-2012 04:26 PM
JeffJacobson
Currently ArcGIS Online allows users to share code (e.g. geoprocessing samples) only by uploading a zip file.  I would like to be able to instead provide a link to an external website (e.g. a GitHub repository page).
MikeMinami
Esri Notable Contributor
Can you put the URL in the description of the item instead?
Mike
JosephJose
I have a google analytics script to be added to a webmap. As you know, it's a script that needs to run once for every access.  Can I use the "Attach code" functionality to collect statistics on the webmap?
MikeMinami
There is no support for attaching and running code from a web map.
thanks
Mike
