Subtypes and ArcGIS Online
3560
05-08-2013 06:47 AM
PaulMcBride
I have a published feature service with subtypes and domains for each subtype.  Everything works well in ArcMap 10 and 10.1 as well as inside the iOS application.  The only place it doesn't work is in ArcGIS online.  Any thoughts?
Below is link to feature service for testing.
http://mccog.maps.arcgis.com/home/item.html?id=6f7af7ad787a4f43a1f25fefebc6bb82
Thank you,
Paul
MikeMinami
Esri Notable Contributor
This seems like a bug. We'll need to check it out. If possible, please leave your test service running.
Mike
PaulMcBride
Mike,
Thank you for the quick response.  I'll leave it running as long as necessary.
Paul
JosephSegretto__GISP
I have experienced the strange behavior from the ArcGIS.com map interface as well.  The feature template works, but the map viewer does not translate the domain descriptions.  When I attempt to add a new feature, the input dialog box shows yellow ! warnings instead of my yes/no coded value domain.  I am interested in knowing when the bug is fixed myself.
If you open the web map with the ArcGIS Explorer online viewer, it will respect the default values for your subtype.  That may help.
