Sort services when overwriting an existing arcgis online service
2571
03-16-2016 01:43 AM
MennoNijhuis1
My organisation has a lot of published arcgis online services. screenshot18.PNG
That makes it very hard to look for the exact one I want to overwrite, and it is not possible to sort the elements in this window. It would be nice to be able to sort, or search, or apply a filter.
RebeccaStrauch__GISP
Good idea. You may want to post this as a suggestion on Esri Arcgis Ideas | Ideas Submission Portal    Check first to make sure there isn't already a similar idea.
Once posted, come back here and post the URL to the idea....and maybe the titel since sometimes links to an idea don't work (depends on whether you are logged in already or not).
KellyGerrow
Esri Alum
What version of ArcMap are you using?
Feature Services are sorted alphabetically within service folders in ArcMap version 10.31 and above when overwriting services. Using version 10.31 and above may improve the find ability of your service during the overwriting process.
If sorting/searching is functionality that you are looking for, please go ahead and log the idea.
-Kelly
