Setting transparency through url parameters
2272
06-17-2012 09:52 AM
ThomasLaxson
Is it possible to set the transparency of a layer through url parameters?
Alternatively, when opening a web map with two layers designated by url parameters, is it possible to open the map with one of them turned off/unchecked?
And while I'm on the topic: is it possible to add feature services to a web mapping application using url parameters?
Thanks.
MikeMinami
Esri Notable Contributor
Here's a help file that documents the available URL parameters on the Map Viewer of ArcGIS.com.
http://help.arcgis.com/en/arcgisonline/help/index.html#//010q00000098000000
hope this helps,
Mike
