Sample Data Attributes - duplicates fields
4582
6
06-03-2014 07:02 AM
LeonScott
When I view an item's details, the sample data attributes duplicates some of the fields.  The fields that are duplicated also do not display any sample values.  I'm wondering if it is related to having null values in the data.
A second issue I am having is the Dataset Map widget is hanging when I try to add one to may site.
Leon
by Anonymous User
Not applicable
Hi Leon,
Can you share a link to the dataset that displays the duplicate fields?
Andrew
LeonScott
Hi Andrew,
Here is the dataset that I have on the portal.
https://www.arcgis.com/home/item.html?id=afae73a966b94765854ba28eee39d190
Thank you for looking into it.
Leon
by Anonymous User
Not applicable
Hi Scott,
Can you also provide the link to your open data site?
Andrew
LeonScott
Sure....
http://gisportal.dedham.opendata.arcgis.com/
It's pretty bare bones at the moment.
Thanks again,
Leon
LeonScott
I have since republished my data overwriting the previous service.  The issue with duplicate field names seems to have been resolved.The reason I republished was that I did not want the GlobalID field to be a part of the service.  I had the field visibility off, thinking that would be sufficient.  As it turns out, I needed to delete the field from my file GDB.
Leon
by Anonymous User
Not applicable
Thanks for the update, and glad to hear its working as expected!
Andrew
