Routing Error Between Two Addresses
4758
10
10-12-2011 04:47 AM
DavidHowell
I am currently using ArcGIS Online by consuming the web services located at:
http://premiumtasks.arcgisonline.com/Server/services/NetworkAnalysis/ESRI_Route_NA/MapServer/NAServe...{our token}
However, when I try to get routing between the following two addresses, I get this error..
"[End Site Name]" in "Stops" is on a non-traversable network element position. Invalid locations detected.
Here are the two addresses:
Start:  4145 So Alameda, Corpus Christi, TX 78414
End: 4525 Gollihar, Corpus Christi, TX 78411
The End address does get a valid geocoding from ESRI, so it would seem that the address is fine as far as ESRI finding it.
I've tried using a number of different start addresses, but it always gives this error for this end address.
Here are the NAServerRouteParams that I am explicitly setting with our code...
routeParams.DirectionsLengthUnits = esriNetworkAttributeUnits.esriNAUMiles;
routeParams.FindBestSequence = false;
routeParams.IgnoreInvalidLocations = false;
routeParams.PreserveFirstStop = true;
routeParams.PreserveLastStop = true;
routeParams.ReturnCompactDirections = true;
routeParams.ReturnDirections = false;
routeParams.ReturnMap = false;
routeParams.ReturnRouteGeometries = false;
routeParams.ReturnStops = false;
Any ideas?
DavidHowell
Adding '.DoNotLocateOnRestrictedElementsSpecified = true' seemed to do the trick.  For now, I didn't change suggestion #2.  If I have problems in the future, I will look into making that change.
Thanks for all the help Mike.  Thank the developers for me.
