Rounding or Dollar Format in Arcade
5189
09-25-2019 02:16 PM
joerodmey
Does arcade support rounding of decimal numbers or applying a money format? Right now Arcade is spitting out 6.2568 for example but I only want to see 6.26
Thanks
XanderBakker
Esri Esteemed Contributor
Hi Joerodney ,
In addition to the solution provided by Jeff Ward you can also use the Text function to format a value:
Text($feature.fieldname, "$ #.00")
JeffWard
Honored Contributor
What if you tried
"$" + Round($feature.fieldname, 2)
Mathematical Functions | ArcGIS for Developers
Jeff Ward
Summit County, Utah
XanderBakker
Hi Joerodney ,
joerodmey
Perfect!
