Pulling attachments
1119
05-01-2013 02:53 PM
JonathanHaller
I created a hosted feature service from ArcMap. I enabled attachments and had a weekend of casual test collections. The attachments show up in AGO and there are copies stored on my phone. I want to pull all the attachments in one shot so I brought the hosted feature service into ArcMap and created a local copy for edit. Then I went to that local copy to download the attachments but it does not recognize that they are there. When I go to 'manage' and 'enable attachments' it is greyed out.
Am I missing a step? When I downloaded it as a shapefile it came with Global IDs, do I need to set that up in the local copy? Or is there a way to get a field that autofills with the image name from the phone? This way I could take my phone local copies and just download and field calculate out the names.
JonathanHaller
I had some time to figure out where I went wrong on this.
Originally I published an editable layer from ArcMap and then loaded it into an AGOL map. I enabled attachements from AGOL and did my field test collection. Bring it back into ArcMap and create a local copy for edit and no attachments are there.
If you set up attachments in ArcCatalog and then publish it you will get your attachments when you bring it back in. Now you still have to go into each record to download them, but you also get the table with their name, which matches the name in the mobile device, so if you end up with hundreds of photos you can pull them off the device, then join the table to the shapefile and field calculate out their new location.
Probably too gauche to give myself an 'answer.'
