Published layer configuration not supported in Map Viewer Classic
1817
07-23-2024 06:34 PM
kriselise322
Hi everyone! I'm trying to publish a layer I made in the ArcGIS Pro app but whenever I do I get the notification "These layers have configurations that are not supported in Map Viewer Classic." There is no specification on what the configurations are, so I don't know how to change it. It's a pretty simple layer-- I just manually drew polygons and there's some additional info in the attribute table. Does anyone have any ideas? I need to use Map Viewer Classic because I want to embed the map into a website.
kriselise322
Never mind. I feel silly now. I clicked "use symbol types compatible with all clients" while sharing the webmap from ArcGIS Pro and it worked.
kriselise322
RussRoberts
Esri Notable Contributor
As a side note if you want to use a web map with Map Viewer configuration like popup elements,  vector symbols, label classes and more - I would recommend using an Instant App and that will give you the embed snippet similar to Map Viewer Classic.
