Publish Service URL To ArcGIS Online
709
07-03-2013 06:12 AM
freddywatimena
Hi Forums,
I there any possibility to Publish Service URL To ArcGIS Online using python methods ?
Or without access it interactively .
in this link is sample for Publish To ArcGIS Online but the parameters is service definition file.
http://resources.arcgis.com/en/help/main/10.1/index.html#/Sign_In_To_Portal/00540000001t000000/
MikeMinami
Esri Notable Contributor
What are you trying to publish? If you want to publish a map, you need to create a service definition first. You can step through the normal publishing process, and instead of publishing to a server or online, you can write out a SD file. Then you can publish this file. Make sure you author this file for publishing to online. There are differences between SD files authored for ArcGIS Server and those authored for ArcGIS Online.
Mike
freddywatimena
Mr. Minami,
Thanks for replying, we got arcgis server connected to arcgis portal ( arcgis online ).
And what we trying to do is , automate populate the portal with services we got on arcgis server.
Is it possible to do it through python code ?
We already automate on making SD files to it.
