Public web app access require login
3205
9
08-23-2021 04:28 AM
Labels (2)
xueyuanyao
Dear sir/madam
I create a public webapp,but when i share it with each other, it still need to be logined,i want to know why.here is my linke: https://yaae4lifuzwazdib.maps.arcgis.com/apps/webappviewer/index.html?id=dcc06a25779a45749f69e1b58bd...
is it need to be paid to ESRI ltd?I dont know,i hope some one can help me .
thanks again
Tags (1)
DavidPike
MVP Notable Contributor
did you Allow anonymous access to your organization?
https://doc.arcgis.com/en/arcgis-online/administer/configure-security.htm
xueyuanyao
yes,i allowed,i cant figure it out ,can you help me ?
Kishore
Hi xueyuanyao,
Your elivation map service "Elevation/World_Hillshade/MapServer" from ibasemaps api required token.
You can save the credentials while adding the service as an item in your portal to bypass this situation or user must login.
Regards,
Kishore
Regards,
Kishore
xueyuanyao
thanks,but how to do it?
Kishore
ibasemaps api is a federated server? or you add the item in the portal content ?
Regards,
Kishore
xueyuanyao
My account is free,is it ok?do you know how to add basemap to portal content?
Kishore
why dont you use free basemap instead elevation map?
Regards,
Kishore
xueyuanyao
actually,it is free,the base map is topographic map which is in gallery in arcgis online,and i added shp which is zip as a layer to the basemap.
xueyuanyao
i cant figure it out,it lasts 3days,i tried every thing,sadly
