Problem with geometry function: STGeomFromText
1031
03-05-2013 09:45 AM
cristianorellana
From any client station can not add or modify a record with SQL, using geometry function: STGeomFromText
The error I get is:
[Microsoft] [ODBC SQL Server Driver] [SQL Server] INSERT failed because the following SET options have incorrect settings: 'QUOTED_IDENTIFIER'.
Verify that SET options are correct and can be used with indexed views and / or indexes on computed columns and / or filtered indexes and / or query notifications and / or methods of XML data type and / or spatial index operations. (42000,1934)
However this can be done from the database in server and the same user (administrator).
