Problem accessing feature layer on cloud (arcgis online)
3061
11-13-2014 12:25 PM
JonathanGagnon1
Hi everyone,
I'm using the Access feature data in the cloud sample with my own service from ArcGis online, i have no particular error in my code and my basemap appear in the app. Can't find why my feature layer "monuments" doesn't appear. Any ideas? Thanks!
MainActivity
package com.arcgis.regeul_s;
import android.app.Activity;
import android.app.ProgressDialog;
import android.graphics.Color;
import android.os.AsyncTask;
import android.os.Bundle;
import android.view.LayoutInflater;
import android.view.Menu;
import android.view.MenuItem;
import android.view.ViewGroup;
import android.widget.TextView;
import com.esri.android.map.Callout;
import com.esri.android.map.GraphicsLayer;
import com.esri.android.map.Layer;
import com.esri.android.map.MapView;
import com.esri.android.map.ags.ArcGISFeatureLayer;
import com.esri.android.map.event.OnSingleTapListener;
import com.esri.android.map.event.OnStatusChangedListener;
import com.esri.core.geometry.Envelope;
import com.esri.core.geometry.Point;
import com.esri.core.map.Feature;
import com.esri.core.map.FeatureResult;
import com.esri.core.map.Graphic;
import com.esri.core.symbol.SimpleMarkerSymbol;
import com.esri.core.tasks.query.QueryParameters;
import com.esri.core.tasks.query.QueryTask;
public class REGEUL_SActivity extends Activity {
    MapView mMapView;
    private ArcGISFeatureLayer mFeatureLayer;
    GraphicsLayer mGraphicsLayer;
    private Callout mCallout;
    private Graphic mIdentifiedGraphic;
    private int mCalloutStyle;
    private ViewGroup mCalloutContent;
    boolean mIsMapLoaded;
    private String mFeatureServiceURL;
    ProgressDialog progress;
    // The query params switching menu items.
    MenuItem mQueryMdMenuItem = null;
    MenuItem mQueryPkMenuItem = null;
    MenuItem mQueryAuMenuItem = null;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.main);
       // Retrieve the map and initial extent from XML layout
        mMapView = (MapView) findViewById(R.id.map);
        // Get the feature service URL from values->strings.xml
        mFeatureServiceURL = this.getResources().getString(R.string.featureServiceURL);
        // Add Feature layer to the MapView
        mFeatureLayer = new ArcGISFeatureLayer(mFeatureServiceURL, ArcGISFeatureLayer.MODE.ONDEMAND);
        mMapView.addLayer(mFeatureLayer);
        // Add Graphics layer to the MapView
        mGraphicsLayer = new GraphicsLayer();
        mMapView.addLayer(mGraphicsLayer);
        // Set the Esri logo to be visible, and enable map to wrap around date line.
        mMapView.setEsriLogoVisible(true);
        mMapView.enableWrapAround(true);
        // Get the MapView's callout from xml->identify_calloutstyle.xml
        mCalloutStyle = R.xml.identify_calloutstyle;
        LayoutInflater inflater = getLayoutInflater();
        mCallout = mMapView.getCallout();
        // Get the layout for the Callout from
        // layout->identify_callout_content.xml
        mCalloutContent = (ViewGroup) inflater.inflate(R.layout.identify_callout_content, null);
        mCallout.setContent(mCalloutContent);
        mMapView.setOnStatusChangedListener(new OnStatusChangedListener() {
          private static final long serialVersionUID = 1L;
            public void onStatusChanged(Object source, STATUS status) {
                // Check to see if map has successfully loaded
                if ((source == mMapView) && (status == STATUS.INITIALIZED)) {
                    // Set the flag to true
                    mIsMapLoaded = true;
        mMapView.setOnSingleTapListener(new OnSingleTapListener() {
            public void onSingleTap(float x, float y) {
                if (mIsMapLoaded) {
                    // If map is initialized and Single tap is registered on screen
                    // identify the location selected
                    identifyLocation(x, y);
     * Takes in the screen location of the point to identify the feature on map.
     * @param x
     *          x co-ordinate of point
     * @param y
     *          y co-ordinate of point
    void identifyLocation(float x, float y) {
        // Hide the callout, if the callout from previous tap is still showing
        // on map
        if (mCallout.isShowing()) {
            mCallout.hide();
        // Find out if the user tapped on a feature
        SearchForFeature(x, y);
        // If the user tapped on a feature, then display information regarding
        // the feature in the callout
        if (mIdentifiedGraphic != null) {
            Point mapPoint = mMapView.toMapPoint(x, y);
            // Show Callout
            ShowCallout(mCallout, mIdentifiedGraphic, mapPoint);
     * Sets the value of mIdentifiedGraphic to the Graphic present on the
     * location of screen tap
     * @param x
     * @param y
    private void SearchForFeature(float x, float y) {
        if (mapPoint != null) {
            for (Layer layer : mMapView.getLayers()) {
                if (layer == null)
                    continue;
                if (layer instanceof ArcGISFeatureLayer) {
                    ArcGISFeatureLayer fLayer = (ArcGISFeatureLayer) layer;
                    // Get the Graphic at location x,y
                    mIdentifiedGraphic = GetFeature(fLayer, x, y);
     * Returns the Graphic present the location of screen tap
     * @param fLayer
     *          ArcGISFeatureLayer to get graphics ids
     * @param x
     * @param y
     * @return Graphic at location x,y
    private Graphic GetFeature(ArcGISFeatureLayer fLayer, float x, float y) {
        // Get the graphics near the Point.
        int[] ids = fLayer.getGraphicIDs(x, y, 10, 1);
        if (ids == null || ids.length == 0) {
            return null;
        return fLayer.getGraphic(ids[0]);
     * Shows the Attribute values for the Graphic in the Callout
     * @param calloutView a callout to show
     * @param graphic selected graphic
     * @param mapPoint point to show callout on map
    private void ShowCallout(Callout calloutView, Graphic graphic, Point mapPoint) {
        // Get the values of attributes for the Graphic
        String matricule = (String) graphic.getAttributeValue("Matricule").toString();
        String mater = (String) graphic.getAttributeValue("Materialisation").toString();
        String latitude = graphic.getAttributeValue("Latitude").toString();
        String longitude = graphic.getAttributeValue("Longitude").toString();
        String altitude = graphic.getAttributeValue("Altitude").toString();
        String x_utm19 = graphic.getAttributeValue("X_UTM19").toString();
        String y_utm19 = graphic.getAttributeValue("Y_UTM19").toString();
        String x_mtm7 = graphic.getAttributeValue("X_MTM7").toString();
        String y_mtm7 = graphic.getAttributeValue("Y_MTM7").toString();
        String hauteur = graphic.getAttributeValue("Hauteur").toString();
        String ondul = graphic.getAttributeValue("Ondulation").toString();
        String xi = graphic.getAttributeValue("Xi").toString();
        String eta = graphic.getAttributeValue("Eta").toString();
        String prec_n = graphic.getAttributeValue("Prec_N").toString();
        String prec_e = graphic.getAttributeValue("Prec_E").toString();
        String prec_v = graphic.getAttributeValue("Prec_V").toString();
        String tech_mes = graphic.getAttributeValue("Tech_mesure").toString();
        String comment = graphic.getAttributeValue("Commentaire").toString();
        // Set callout properties
        calloutView.setCoordinates(mapPoint);
        calloutView.setStyle(mCalloutStyle);
        calloutView.setMaxWidth(325);
        // Compose the string to display the results
        StringBuilder pointMatriculeName = new StringBuilder();
        pointMatriculeName.append("Matricule: ");
        pointMatriculeName.append(matricule);
        TextView calloutTextLine1 = (TextView) findViewById(R.id.Matricule);
        calloutTextLine1.setText(pointMatriculeName);
        StringBuilder pointMaterName = new StringBuilder();
        pointMaterName.append("Matérisalisation: ");
        pointMaterName.append(mater);
        TextView calloutTextLine2 = (TextView) findViewById(R.id.Mater);
        calloutTextLine2.setText(pointMaterName);
        StringBuilder pointLatitudeName = new StringBuilder();
        pointLatitudeName.append("Latitude: ");
        pointLatitudeName.append(latitude);
        TextView calloutTextLine3 = (TextView) findViewById(R.id.Latitude);
        calloutTextLine3.setText(pointLatitudeName);
        StringBuilder pointLongitudeName = new StringBuilder();
        pointLongitudeName.append("Longitude: ");
        pointLongitudeName.append(longitude);
        TextView calloutTextLine4 = (TextView) findViewById(R.id.Longitude);
        calloutTextLine4.setText(pointLongitudeName);
        StringBuilder pointAltitudeName = new StringBuilder();
        pointAltitudeName.append("Altitude: ");
        pointAltitudeName.append(altitude);
        TextView calloutTextLine5 = (TextView) findViewById(R.id.Altitude);
        calloutTextLine5.setText(pointAltitudeName);
        StringBuilder pointX_UTM19Name = new StringBuilder();
        pointX_UTM19Name.append("X_UTM19: ");
        pointX_UTM19Name.append(x_utm19);
        TextView calloutTextLine6 = (TextView) findViewById(R.id.X_UTM19);
        calloutTextLine6.setText(pointX_UTM19Name);
        StringBuilder pointY_UTM19Name = new StringBuilder();
        pointY_UTM19Name.append("Y_UTM19: ");
        pointY_UTM19Name.append(y_utm19);
        TextView calloutTextLine7 = (TextView) findViewById(R.id.Y_UTM19);
        calloutTextLine7.setText(pointY_UTM19Name);
        StringBuilder pointX_MTM7Name = new StringBuilder();
        pointX_MTM7Name.append("X_MTM7: ");
        pointX_MTM7Name.append(x_mtm7);
        TextView calloutTextLine8 = (TextView) findViewById(R.id.X_MTM7);
        calloutTextLine8.setText(pointX_MTM7Name);
        StringBuilder pointY_MTM7Name = new StringBuilder();
        pointY_MTM7Name.append("Y_MTM7: ");
        pointY_MTM7Name.append(y_mtm7);
        TextView calloutTextLine9 = (TextView) findViewById(R.id.Y_MTM7);
        calloutTextLine9.setText(pointY_MTM7Name);
        StringBuilder pointHauteurName = new StringBuilder();
        pointHauteurName.append("Hauteur: ");
        pointHauteurName.append(hauteur);
        TextView calloutTextLine10 = (TextView) findViewById(R.id.Hauteur);
        calloutTextLine10.setText(pointHauteurName);
        StringBuilder pointOndulationName = new StringBuilder();
        pointOndulationName.append("Ondulation: ");
        pointOndulationName.append(ondul);
        TextView calloutTextLine11 = (TextView) findViewById(R.id.Ondulation);
        calloutTextLine11.setText(pointOndulationName);
        StringBuilder pointXiName = new StringBuilder();
        pointXiName.append("Xi: ");
        pointXiName.append(xi);
        TextView calloutTextLine12 = (TextView) findViewById(R.id.Xi);
        calloutTextLine12.setText(pointXiName);
        StringBuilder pointEtaName = new StringBuilder();
        pointEtaName.append("Eta: ");
        pointEtaName.append(eta);
        TextView calloutTextLine13 = (TextView) findViewById(R.id.Eta);
        calloutTextLine13.setText(pointEtaName);
        StringBuilder pointPrec_NName = new StringBuilder();
        pointPrec_NName.append("Prec_N: ");
        pointPrec_NName.append(prec_n);
        TextView calloutTextLine14 = (TextView) findViewById(R.id.Prec_N);
        calloutTextLine14.setText(pointPrec_NName);
        StringBuilder pointPrec_EName = new StringBuilder();
        pointPrec_EName.append("Prec_E: ");
        pointPrec_EName.append(prec_e);
        TextView calloutTextLine15 = (TextView) findViewById(R.id.Prec_E);
        calloutTextLine15.setText(pointPrec_EName);
        StringBuilder pointPrec_VName = new StringBuilder();
        pointPrec_VName.append("Prec_V: ");
        pointPrec_VName.append(prec_v);
        TextView calloutTextLine16 = (TextView) findViewById(R.id.Prec_V);
        calloutTextLine16.setText(pointPrec_VName);
        StringBuilder pointTech_mesName = new StringBuilder();
        pointTech_mesName.append("tech_mes: ");
        pointTech_mesName.append(tech_mes);
        TextView calloutTextLine17 = (TextView) findViewById(R.id.Tech_mes);
        calloutTextLine17.setText(pointTech_mesName);
        StringBuilder pointCommentName = new StringBuilder();
        pointCommentName.append("Comment: ");
        pointCommentName.append(comment);
        TextView calloutTextLine18 = (TextView) findViewById(R.id.Comment);
        calloutTextLine18.setText(pointCommentName);
        calloutView.setContent(mCalloutContent);
        calloutView.show();
     * Run the query task on the feature layer and put the result on the map.
    private class QueryFeatureLayer extends AsyncTask<String, Void, FeatureResult> {
        // default constructor
        public QueryFeatureLayer() {
        @Override
        protected void onPreExecute() {
            progress = ProgressDialog.show(REGEUL_SActivity.this, "", "Please wait....query task is executing");
        @Override
        protected FeatureResult doInBackground(String... params) {
            String whereClause = "COUNTRY='" + params[0] + "'";
            // Define a new query and set parameters
            QueryParameters mParams = new QueryParameters();
            mParams.setWhere(whereClause);
            mParams.setReturnGeometry(true);
            // Define the new instance of QueryTask
            QueryTask queryTask = new QueryTask(mFeatureServiceURL);
            FeatureResult results;
            try {
                // run the querytask
                results = queryTask.execute(mParams);
                return results;
            } catch (Exception e) {
                e.printStackTrace();
            return null;
        @Override
        protected void onPostExecute(FeatureResult results) {
            // Remove the result from previously run query task
            mGraphicsLayer.removeAll();
            // Define a new marker symbol for the result graphics
            SimpleMarkerSymbol sms = new SimpleMarkerSymbol(Color.BLUE, 10, SimpleMarkerSymbol.STYLE.CIRCLE);
            // Envelope to focus on the map extent on the results
            Envelope extent = new Envelope();
            // iterate through results
            for (Object element : results) {
                // if object is feature cast to feature
                if (element instanceof Feature) {
                    Feature feature = (Feature) element;
                    // convert feature to graphic
                    Graphic graphic = new Graphic(feature.getGeometry(), sms, feature.getAttributes());
                    // merge extent with point
                    extent.merge((Point)graphic.getGeometry());
                    // add it to the layer
                    mGraphicsLayer.addGraphic(graphic);
            // Set the map extent to the envelope containing the result graphics
            mMapView.setExtent(extent, 100);
            // Disable the progress dialog
            progress.dismiss();
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.main_menu, menu);
        // Get the query params menu items.
        mQueryMdMenuItem = menu.getItem(0);
        mQueryPkMenuItem = menu.getItem(1);
        mQueryAuMenuItem = menu.getItem(2);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        // Handle menu item selection.
        switch (item.getItemId()) {
            case R.id.Query_MD:
                mQueryMdMenuItem.setChecked(true);
                new QueryFeatureLayer().execute("Medaillon");
                return true;
            case R.id.Query_PK:
                mQueryPkMenuItem.setChecked(true);
                new QueryFeatureLayer().execute("Pk");
                return true;
            case R.id.Query_AU:
                mQueryAuMenuItem.setChecked(true);
                new QueryFeatureLayer().execute("Autre");
                return true;
            default:
                return super.onOptionsItemSelected(item);
    @Override
    protected void onPause() {
        super.onPause();
        mMapView.pause();
    @Override
    protected void onResume() {
        super.onResume();
        mMapView.unpause();
Strings
<?xml version="1.0" encoding="utf-8"?>
<resources>
    <string name="app_name">REGEUL_S</string>
    <string name="spinTitle">Query Customer Data:</string>
   <string name="featureServiceURL">http://http://services3.arcgis.com/D7xw8Tli8HKiA30u/ArcGIS/rest/services/monuments/FeatureServer/0</string>
    <!-- query parameters -->
    <string name="Query_md">Medaillon</string>
    <string name="Query_pk">PK</string>
    <string name="Query_au">Autre</string>
</resources>
