Print Widget Customization APi 4.1
816
02-04-2019 12:46 PM
RobertJensen1
Is there any info on how to customize the print widget. The only data I can find is this:
Print widget | ArcGIS API for JavaScript 4.10
The issues with this are:
The Export box is way too large. I was able to hide some elements of it but ideally would like it to open from an icon or button.
The print widget does not export any pop-up box data. So if a user selects a point and a pop-up box shows on the screen, the only thing that shows up in the export are the map and the legend, which is not very useful in our case. We would like to have the text in the pop-up box also export with the map.
Is it possible to do any customization on this widget? If not, is it possible to get all the existingcode for widget to create a custom widget using that code?
Thanks
Tags (1)
