Online attachments
2603
09-06-2022 01:44 PM
by Anonymous User
Not applicable
where are the documents stored that are used in ArcGIS Online?  I've created attachments in Online with documents from our company server.  are the attachments for the layer just links to those locations?  I didn't place them in the Online environment
RobertCottreau13
my attachments are documents from our company server.
so they are in fact stored in the Online platform and not just as links.  I tested this using a non-company computer to see if I could access them and I can.
thanks.
RhettZufelt
MVP Notable Contributor
See this post to see how to access the attachments stored in the service.  This post if for Arcade, but part 2, step 4 describes how/where the attachments are stored in hosted feature service.
R_
RobertCottreau13
that article discusses geotagged photos?
So, are the attachments only stored as hyperlinks to a location?  If the location is my company's network, then I guess any attachments I put will not be accessible to anyone outside my company?
RhettZufelt
Part 1 of the link discusses how to get geotagged photos in as attachments (you can ignore that since you already have a dataset with attachments), but Part 2 (esp. step 4) tells you how to access the attachments through the REST service.
Not sure how you "created attachments in Online with documents from our company server", but if you enable and add attachments to a feature class, they are stored as BLOBs in the database in the attachments table for that feature class.
If you publish this data as a service, the attachments are available through the service directly.  So, if someone has access to the service, they should also be able to see the attachments.
R_
RobertCottreau13
thanks.
