Normalization error AGO
2012
08-17-2014 04:01 PM
RickThomas
I normalize a symbolization in AGO using two variables that display perfectly by themselves, but the normalized display does not,include all regions. Why? Check http://timeandplace.maps.arcgis.com/home/webmap/viewer.html?webmap=f84d5a36041646718085c00b56196950
MikeMinami
Esri Notable Contributor
This is a bug. The issue is caused by rounding error. The class break ends at 0.2513595342, but the calculated value when carried out with more decimal points ends up falling outside the break.
43171/171750=0.2513595342066958
The source of this bug is actually ArcMap, as the same code is reused for AGOL. This issue is documented in our defect tracking system. No release date set that I can see.
Mike
DonOpgenorth
I've moved your post into the  Arcgis Online space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
MikeMinami
Mike
RickThomas
Thanks Mike -
As long as I know this is not my problem I’ll continue working on the project the map you looked at is part of and let you folks figure out a solution.
Thanks again for taking a look,
Rick Thomas
GeoNet
reply from Mike Minami in ArcGIS Online - View the full discussion
Mike
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in ArcGIS Online by email or at GeoNet
Following Normalization error AGO in these streams: Inbox
