No Attachments found
1046
03-19-2013 12:22 PM
RyanWoehl
I created a point file and enabled attachments on it.  I attached the JPGs to each of the points in ArcGis Desktop and everything works perfectly.  After I publish a feature service of those points and open it in AGOL, the place where the link would be it says "No Attachments Found".  I was wondering if there is some setting that I need to change while sharing the feature service that will make sure the attachments get into AGOL?
RyanWoehl
OK I figured out the problem if anyone else is having an issue.  My Point files had Z and M Values.  After got rid of Z and M values it worked perfectly.  Not sure why...It must be one of the quirks.
