new user help
1251
02-26-2014 01:43 AM
jackwalker
Hi everyone , i am a reatively new user to ARC Gis. i was looking for some help to find some information on something that i would like to do.
At the moment i have a map that has several different shape files on it such as roads , power cables , houses, railway lines. i am trying to find spaces on my map that are outwith a given distances to these few features. So ideally i would like a new shape file that has points that 1000 m away from these features.
As i am a newbie i m not sure what the correct terminology would be for this process. Any direction on wheather this is possible and where i might find some lerning resource on this would be great
Thanks very much
Jack
TimWitt
Jack,
Use the buffer tool with all your existing features and as distance choose 1000m. This will create a buffer polygon around your features.
Once you buffered all layers, the space on your map that is not occupied by a buffer polygon is what you are looking for.
Hope this helps!
Tim
jackwalker
Hi Tim ,
thanks for your help , i was looking into the buffer tool
as i have several layer , will i have to go through each layer and apply the buffer and see whats left afterwards at the end of the process.
Thanks again
Jack
TimWitt
Jack,
You can right-click the buffer tool in your toolbox and choose "batch" to apply the same buffer too all your layers.
Tim
