New Map Viewer Popup Field Ordering
13677
16
05-18-2021 12:58 PM
AdamMesser1
Field order is being sorted alphabetically in the popup configuration when a feature service is added to the New Map Viewer. Is there a way to make the map viewer honor the original field ordering as shown in the feature table?
Resorting the original order is problematic as field order is set to facilitate ease of data viewing or entry. Unfortunately, the caveat on the popup configuration mentions "Popups offered in map viewer are not compatible with all apps." This appears to be the same issue that @MarkEastwood experienced with his collector post. We are working on a configurable editing app which apparently does not honor new map viewer popup configurations. I tried using Experience Builder, assuming that the problem may be due to the underlying javascript api 3x/4x compatibility, but EB does not yet have an editing widget. It does not appear the popup reorder is honored in Field Maps either. Given this we are spending time to redo our work to use the Map Viewer Classic unless Esri has recommendations on using the new map viewer for editing wit original field order.
ThomasHamill
Here's how to reset the layer pop-up to the default attribute order of its schema in the Map Viewer (i.e. reverse the automatic alphabetical sort on fields in the pop-up that seems to be the default when a new layer is added to a web map):
1) In the Map Viewer (not Map Viewer Classic), select the layer of choice from the Layers Pane table of contents (left sidebar)
2) Select the Pop-ups button from the layer settings (right sidebar)
3) Select the existing Fields list button with the fields currently in alphabetical order
4) Click the Select fields button (which will change to Deselect all)
5) Click the Deselect all button (which will change back to Select all) to turn off all fields
6) Click Select all once more—notice the order reset in the "dimmed" Fields list menu that appears behind the active Select fields menu
7) Click Done at the bottom of the Select fields menu
😎 To save these changes, don't forget to click Save from the Save and open menu (left sidebar)
Related idea: Show Pop-ups in Attribute order rather than Alphabetical by Default
Kindest Regards,
t
RyanTucker
This workaround is better than using map viewer classic.  Thank you.
ESRI still needs to make this the default behavior.
cat206
This is so helpful! Thank you Thomas!
AdamMesser1
@ThomasHamill Thank you for the solution and link to related post.
ThomasHamill
Also, I'm seeing that while this is a solution for the attribute pop-up in the Map Viewer, the field order of the edit menu/dialog in the Map Viewer remains unchanged and would still unfortunately show the default attribute order of the layer's schema; I don't believe the field order in the edit menu can be customized.
Hopefully Esri can ensure the field order changes are propagated down to the attribute edit menu as well.
Kindest Regards,
t
by Anonymous User
Not applicable
Hi All,
I received this Esri message today: Updates have been made to the following defect which you are associated with:
ENH-000140303 - Add a functionality to the map viewer to resort a field list based on the layer field or alphabetical order.
Status: Implemented (Learn More)
Version Implemented:  Planned Release Date: Q1 2025
Tiff
Hi @Anonymous User just to confirm has this already been implemented, or is it slated for the Feb 2025 update?
