Collector Field Ordering
293
10-20-2020 01:24 PM
MarkEastwood
Hi All,
I have created a web map using the Map Viewer Beta. For one of the layers in the map I manually reordered the fields in the configure-popups panel. When I view the map in Collector the new field ordering is not supported. It looks like Collector is still using the default field ordering that I see when viewing it in the configure fields panel. See images below.
Image of popup and configure popup tab in Map Viewer Beta:
Image of Collector popup and configure fields panel in Map Viewer Beta:
All of these images are at the top of the popup. Is there any way to manually reorder fields in Map Viewer Beta and get those changes to show up in Collector. This workflow was possible in the original Map Viewer. Thanks for any help.
Mark
