Need help with Arcade Data Expression in Dashboard
1911
03-08-2023 11:13 PM
M_M
I am new to Arcade and have found myself stuck.  I am writing a data expression for dashboard and I can't figure out how to write a calculation.  I get an error with everything I've tried.
  • I need to multiply the Tally field for records with a 'Plot_Size' of 0.02 by 50, and multiply any records with a 'Plot_Size' of 0.01 by 100.
  • I created a filter to parse out records with 'Plot_Size' 0.02 & 0.01.  I tried to create a new var plot_exp to do the calculation but it's not working (line 10).
  • I also tried to do the calculation in my GroupBy (line 20) and it's not recognizing the var I created in the filters on line 6-7.
I also tried to create a dictionary, and use that but I couldn't get that to work either 🙂
My end goal is to multiply the 'Tally' field for each 'Stand_No' by 50 or 100 (as determined by 'Plot_Sizes' of 0.02 and 0.01).  I then need to find the average for those new (Tally*50 and Tally*100) numbers for each 'Stand_No'.
  var p = 'https://maps.arcgis.com'
  var itemId = 'a8af124e92af44579e3fd07bb59ebb4c'
  var fs = FeatureSetByPortalItem(Portal(p), itemId, 0, ['Stand_No', 'Tally', 'Plot_Configuration', 'Plot_Name', 'Plot_Status', 'Plot_Size', 'DBH', 'Height', 'Cruiser_Name', 'Exit_Plot_Time'], false)
  //Separate Plot Size into 2 groups for planting
  var plot50 = Filter(fs, 'Plot_Size = (0.02)');
  var plot100 = Filter(fs, 'Plot_Size = (0.01)');
  var TPS = 0
  //Multiply the plot size in plot50 by 2,500, multiply the plot size in plot100 by 10,000)
  var plot_exp = [{name: 'TPS', expression: '(Tally * 2500)', statistic: 'MAX'}]
  //return plot_exp
  var summary = GroupBy(fs,['Stand_No','Plot_Configuration','Plot_Size', 'Cruiser_Name'],
    [{name: 'TallySum', expression: 'Tally', statistic: 'SUM'},
      {name: 'TCount', expression: '1', statistic: 'COUNT'},
      {name: 'AvgDBH', expression: 'DBH', statistic: 'AVG'},
      {name: 'AvgHeight', expression: 'Height', statistic: 'AVG'},
      {name: '50TPS', expression: '(@plot50 * 2500)', statistic: 'AVG'}])
        Console(summary)
  return summary
  //Goal is to obtain the Trees per Acre per Stand for each Stand
jcarlson
The SQL expressions used in GroupBy will recognize numeric and text data, but not objects like FeatureSets. If you need to apply a different calculation based on a field's value, you can do that in the SQL expression using CASE.
var plot_exp = `CASE
    WHEN Plot_Size = 0.02 THEN Tally * 0.02
    WHEN Plot_Size = 0.01 THEN Tally * 0.01
    ELSE Tally -- or some other default value
END`
 Just swap that in as one of the expressions in your GroupBy function, and you should get results like you expect.
- Josh Carlson
Kendall County GIS
jcarlson
END`
- Josh Carlson
Kendall County GIS
M_M
That works perfectly, thank you so much!! I really appreciate the help! 🙂
