Moving layers and web maps from one subscription to another
2663
03-24-2016 07:50 AM
YigalMuntner
Has anyone tried to move layers and web maps from one subscription to another? I'm using https://ago-assistant.esri.com/ to do that, but it is is working only on feature layers. I'm looking for a solution to transfer also Tiled Layers.
AdrianWelsh
MVP Honored Contributor
Hi Yigal,
Are these subscriptions all in the same organization? If so, and if you are in an Administrator role, you can transfer the content on your ArcGIS Online organization page.
YigalMuntner
Hi Adrian,
A subscription is an Organization. I mean moving tiled layers between two organizations, when I know the credentials of both administrators.
Yigal
AdrianWelsh
oh, thanks for the clarification! I am not sure how to accomplish this!
Hopefully someone else can help out on this board.
YigalMuntner
Thanks Adrian,
By the way, if you are looking for transferring feature layers, then https://ago-assistant.esri.com/
will do the job for you.
Yigal
RebeccaStrauch__GISP
Tools · Esri/ago-admin-wiki Wiki · GitHub    is a good resource listing most/all the tools available.  Work a browser bookmark and/or github watch.  It has links and short description.
