Map Viewer Legend - when line features are set to 'adjust width automatically' the line symbols do not display in the Legend
1403
06-05-2023 12:58 PM
DavidColey
MVP Frequent Contributor
Hello -
When ever I set any line features (hosted or referenced) to automatically adjust the width in the map viewer, the line symbols no longer display in the Map Viewer Legend. This unfortunately carries over to any Instant App or ExB legend as well.
David
Tags (1)
RussRoberts
Esri Notable Contributor
Wont be in the release coming around UC but is planned for the fall update.
RussRoberts
We have a known issue on the API side we are currently investigating. It most likely wont be included in the upcoming release. Because this is in API issue you see it across other apps that use the same version of the JS API.
DavidColey
Thanks for the feedback @RussRoberts   To be clear, are you saying the issue won't be repeated in the upcoming release or that the fix won't be included in the upcoming release?
David
RussRoberts
DavidColey
ok, so the fix wont be in this release, got it.
