Map Packages
4774
12
10-23-2009 07:56 PM
TedCronin
Original Post Date: Oct 23, 2009 8:56 PM PDT
Will ArcGIS Online suppport the loading of Map Packages or perhaps we can have access to a test instance?
SabrinaGonzalez_Toro
Map packages will be supported for ArcGIS explorer?  If so. Will we have access to an ArcGIS Explorer version to test this?
TedCronin
Hi Pam,
I tested this out and confirmed the behavior you are reporting. I have logged the following bug to address this issue.
NIM050663: Layer packages created with 9.4 do not open in 9.3.1
It is our intention that cross version functionality with layer packages does work in the final release of 9.4. We will also be providing an option to create earlier verisons of the Geodatabase with ArcGIS Desktop, but it is currently not a function of 9.4 Beta One release.
I hope this helps address some of your questions and concerns.
Thank You,
Andrew
Has this been addressed for 10 Pre, by chance?
by Anonymous User
Not applicable
Hi Ted,
I just did some quick testing on 10 pre and it should be fixed.
Cheers,
Andrew
