Line labeling issues
168
3 weeks ago
JoshHergert
I am curious if anyone else is having issues with labeling on line features. One of my works clients had pointed it out to me and as I tired to see what is going on it’s even more confusing.
when using just one field to show it as a label even on one line segment  it is showing two labels at the same location on the line. If the center option is selected the two labels sit on top of each other. This was all with in our clients account. I tried it within my account and the same issue is happening. If I select above or below center the two labels parallel the line
Just wanted to see if anyone else is having this issue or know how to fix it. When I bring the web map into pro it works perfectly
thank you josh
RussRoberts
Esri Notable Contributor
We fixed this issue last night and should be resolved this morning.
