Line label offset without label duplication
45
yesterday
Jennifer_Parmeley
Is there a simple way to offset line labels in a web map?
I have line labels with a 2pt halo to increase visibility. We'd like a little separation between the line and the label.
I've tried an arcade expression (two different ways) and it's duplicating my label text.
text($feature.SewerMainID) + "; " + $feature.PipeDiameter + 'in ' + Round($feature["Shape.STLength()"], 2) + "ft" + TextFormatting.NewLine + TextFormatting.NewLine
var tsewerid = text($feature.SewerMainID) + "; "
var len_2 = Round($feature["Shape.STLength()"], 2) + "ft"
`${tsewerid} ${$feature.PipeDiameter}in ${len_2}
Also tried adding a . in the second line - which probably won't be noticed by the user - but the entire text block is still being duplicated.
The allow overrun and repeat label settings don't change anything. Am I missing a simple setting for this?
RussRoberts
Esri Notable Contributor
This is not exposed just in our style panel for labeling but you can modify the web map or layer JSON in ago-assistant and set the yoffset within the symbol under the labelinginfo.
