labelling question - Dynamic labels which centre on the screen view
1997
6
11-15-2024 02:53 AM
narmour1979
Hi
I am working for a utilities customer who needs to clearly label features on a map that are designated critical assets. I am doing this by applying a simple arcade function to have the label read:
"CRITICAL ASSET - CONTACT xyz"
Problem is, many of these critical assets are large polygons covering many square kilometres, and the label is only applied once to each polygon. If the area in which the engineer is working is far away from where the label sits, they could have no idea the asset is critical and could be putting themselves in danger.
I can have this label centre on the screen in ArcGIS Pro, but this functionality doesn't seem to be available in ArcGIS Online. Is there any way of making this possible?
Tags (3)
RussRoberts
Esri Notable Contributor
This is on our roadmap to support dynamic centroid placement for the polygons so if you are only viewing a part of the polygon or zoomed in on one and are not at the center of the polygon the label will find the center of the polygon in view. We were hoping to get it into this recent update but were not able to. We are aiming for this for the release coming in the new year. This will not require any map updates or arcade changes.
RussRoberts
narmour1979
Brilliant news thanks for replying! I'll keep an eye out for this in future updates.
LarryFox
The dynamic centroid placement for polygon labels doesn't seem to be working.  Did that make it into the last update or is that still on the roadmap?
RussRoberts
Its not in yet and still on our road map. This upcoming release has some improvements to deconfliction and multipoint support and hopefully the following update we will get the centroid placement in.
JimCarmichael1
Definitely would be great to get this pushed out as soon as possible in the next update or two, if possible. Really affects our users who work with large polygons when they zoom in to edges and no label appears.
LarryFox
Thank you.
