Issue with publishing a Feature Service
25784
72
07-03-2013 06:14 AM
MatthesRieke
Hi all,
I have been trying to publish a hosted Feature Service based on a local data frame using ArcMap 10.1's "Share As/Service" feature (following the tutorial at http://resources.arcgis.com/en/help/arcgisonline/index.html#//010q00000087000000 ). Though, the service appears in "My Contents" (as a Service Definition, is that correct?) it is not published or accesible in any way (I have been trying to access it from GeoEvent Processor Beta). When I try to publish it manually (through the Item view's "Publish" button), I get an error message "Invalid tenant Id Invalid tenant login".
Publishing the same local data frame to my own ArcGIS Server 10.1 instance works. The TileService for the same data frame works as well. I am currently using the 30-day trial subscription, could this be an issue?
Thanks in advance,
Matthes
fredfred1
Hi Mike,
I created my trial account yesterday and still now I can't publish the feature service.
AlbertoAloe
Mike,
I have the same problem (see above).
I'm about to open a ticket with support.
Alberto
MikeMinami
Esri Notable Contributor
This is an isolated problem with some organization accounts. Please call tech support and give them your subscription ID and we will fix the problem. Or alternatively, post your subscription ID here.
Sorry for the inconvenience,
Mike
Guillermo_JoséCiampagna
Mike,
My ID si: 8554167900
I have the same problem: "Invalid tenant Id. Unable to find tenant in database. Invalid tenant login."
MikeMinami
Guillermo,
This should be fixed now. Let us know if you have any problems.
Mike
Thanks Mike! Now we can upload feature services in the organization.
I need one more thing. We are Esri Silver Partner and we administrate this
510 users organization.
The want to use the corporative login but it doesn´t work with Salesforce
SAML login (identity provider) that is approved by ArcGIS Online.
When we use the metada generated in ArcGISOnline in Salesforce (URL ACS -
Acertion Customer Service), that produce an error when we want to login in
ArcGIsOnline:
Invalid_SAMLResponse error_description=Unable to login using Idp Unable to
validate SAML response
We are not sure if the configuration is correct or not, you have
configuration details for Active Directory and OpenAM but what about others?
Our project is in danger for this security issue.
Thanks in advance for your feedback!
Greatings from Argentina.
Guillermo.-
Guillermo Ciampagna
Director general
Pje. Santo Tomás 341, X5000LAA
Ciudad de Córdoba, Argentina.Tel/fax: 00-54-351-4259096
Móvil: 00-54-351-5-600582
Skype: gciampagna
*[email protected]
<[email protected]>*
www.ciampagna.com.ar <http://www.ciampagna.com.ar>
2014-10-03 12:24 GMT-03:00 Mike Minami <[email protected]>:
GeoNet
<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo8h7SGfRSMkw-2FpvHGF9-2FW3rK-2Bvs1kL9-2FnG6jjf2NZhrLDz0M-2BrY-2By9IaziQEKVk3Hg-3D-3D_OFuVmkqlPUFejGZHEiAZh-2BwILr1HpGwmdrr1CIh1jm7Bu8JytTSHXy937UHDKVyTk3g7EbG-2B1mZDs2EJgU8Wv-2BI59GgW-2BiULCoRv4h-2BGF4Fv4wSGgpdtlKRbMLvSN7o550SsRRIzfSXhKGQ-2FA8ecu7Cc9k6EekI5xDCcpsZ-2F7HWN-2BJV0lv4PWjEEIjUR-2B5-2FvK9tZQtTiUiG5m-2BVjNw-2FtflKByD-2BsHn-2BV6ZOMqqUlwIpQyJeN5BTGrvmHaV7NG8tGNd5adwa41ewXZ6PvTg8wUXTtOXX1gb6xZCPW-2F9OsSLW9OJ5gDp3JUsb3lpbRNkzKB57UW3LQHxNTnovKfC0GCQ-3D-3D> Issue
reply from Mike Minami
<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK4-2BSzaYAWbep1g7MeWcxXKCxYil2QP2ixsUiesw0zHBPVPx3wXvP76-2FW8JxYmmawimE-3D_OFuVmkqlPUFejGZHEiAZh-2BwILr1HpGwmdrr1CIh1jm7Bu8JytTSHXy937UHDKVyTk3g7EbG-2B1mZDs2EJgU8Wv-2BI59GgW-2BiULCoRv4h-2BGF4Fv4wSGgpdtlKRbMLvSN7o550SsRRIzfSXhKGQ-2FA8ecu-2Bdo9cywK1IL6o4bpeKC4S3hNSZBSVoYd0oesIASh4anyQ0YGAT7mtvkGKl4JMv-2Bao4Alt1-2BvfVySkSfpmYcOMUqPlpFc2Cd-2BvyGKBiL3zh3AdzCZV57mJp6gKRadoUT13RnXDTQ8yO7zPjMkhUvplYVsD6mmSPGGjZdjamMwsLs0R2FDbNyIubec2ui78BGQg-3D-3D>
in ArcGIS Online - View the full discussion
<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEw5MnIAPP2CxYnSmG7P20QVcB54c8KsvRmcHZ-2BjEnbrBxRV-2BCWtiY11vwPIt22FNF0-3D_OFuVmkqlPUFejGZHEiAZh-2BwILr1HpGwmdrr1CIh1jm7Bu8JytTSHXy937UHDKVyTk3g7EbG-2B1mZDs2EJgU8Wv-2BI59GgW-2BiULCoRv4h-2BGF4Fv4wSGgpdtlKRbMLvSN7o550SsRRIzfSXhKGQ-2FA8ecu80AO56LDV2wjlYQfgJAlraloJz6WuQo-2F7Q11431KPTdTRaesnhjmBj7FtuUcCXosddU6U98Z0Ddve4nHvU3CQi2FfLEhuxqNlHFy0LARnDID0Ov450VuHtstW3IXKW3k2m2Z0wAFc7JkmZfawVM-2F7MGU7Pp2KOU3hEh3bOHf0Taih0rUIkmhbrIB5F2AdyzVg-3D-3D>
RajkumarPadmanabhan
Hi Guillermo,
Can you please post the SAML response from Salesforce?
Thanks.
Hi Rajkumar!
This is the configuration data that I have in Salesforce:
<?xml version="1.0" encoding="UTF-8"?><md:EntityDescriptor xmlns:md="urn:oasis:names:tc:SAML:2.0:metadata" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" entityID="https://testlogin--SXBA.cs11.my.salesforce.com" validUntil="2024-09-30T16:51:09.372Z">
  <md:IDPSSODescriptor protocolSupportEnumeration="urn:oasis:names:tc:SAML:2.0:protocol">
  <md:KeyDescriptor use="signing">
  <ds:KeyInfo>
  <ds:X509Data>
  <ds:X509Certificate>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</ds:X509Certificate>
  </ds:X509Data>
  </ds:KeyInfo>
  </md:KeyDescriptor>
  <md:NameIDFormat>urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified</md:NameIDFormat>
  <md:SingleSignOnService Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST" Location="https://testlogin--SXBA.cs11.my.salesforce.com/idp/endpoint/HttpPost"/>
  <md:SingleSignOnService Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-Redirect" Location="https://testlogin--SXBA.cs11.my.salesforce.com/idp/endpoint/HttpRedirect"/>
  </md:IDPSSODescriptor>
</md:EntityDescriptor>
Thanks for your help!! Do not hesitate in ask me more details by e-mail [email protected]
RajkumarPadmanabhan
Hi Guillermo,
The data you have posted is the metadata information for Salesforce. If you are still unable to use Salesforce, please attempt to sign in when Salesforce has been configured as the identity provider. During the log in attempt, please capture and send me the decoded SAML response. You can get the SAML response in Firefox by using the SAML tracer add on.
Regards,
Raj.
Aye_SweLatt
I'm having the save problem.
My ID is 3619726171
