Is it possible to edit Featuer Service attribute only in ArcGIS.com
764
09-22-2011 09:33 PM
JackZHANG
I have a map service with Feature Access enabled and added to ArcGIS.com. When edit, by default user can edit both the attribute as well as geometry. Now I'm wondering if there's a way to setup so user could only edit the attribute not geometry? Any advices will be appreciated!
regards,
Jack
MikeMinami
Esri Notable Contributor
In ArcGIS Online, editing includes both feature and geometry editing. There is no way to disable one or the other. You could, however, write your own application. Here's a sample that seems to do what you're looking for. Try viewing the live sample.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/ed_attribute_inspector.html
This is part of the JavaScript API.
http://help.arcgis.com/en/webapi/javascript/arcgis/index.html
Hope this helps,
Mike
JackZHANG
Thanks Mike for the advices!
