insert my logo on the map
4078
6
05-31-2013 12:01 AM
lionelQUIRIE
Sorry for my english but i'm french.
I want to insert my logo in the map i have created but i don't see where i must do it.
I have already done it in this map (the link below) one year ago but i don't remember how
http://www.arcgisonline.com/apps/OnePane/basicviewer/index.html?appid=68cc15a1f4634afeb98e77e9fa2d40...
Thanks for your help!
Lionel Q.
MikeMinami
Esri Notable Contributor
Go to the item page of your web application. You should see a "Configure" button. You will then be able to specify a URL to an image to display as a logo over the map.
Mike
lionelQUIRIE
Thanks a lot for your reply, but i don't know if I do well. surely not because I don't see the logo on the map.
After a clic on the "modifier" button ("configurate" (the button with a pen ?)), I have filled the two localisations where I can put a url image (in french "Description" and "Contraintes d�??accès et d�??utilisation") (see the image attached).
> No logo appears in the description or on the map!
I don't know what I can do...
Thanks for your help.
MikeMinami
See attached image.
Hopefully this helps.
Mike
lionelQUIRIE
Thanks for your repply,
I don't have this button "configurer l'application" is it normal?
Maybe I don't have the rights to have it? 😞
Lionel
MikeMinami
Are you the owner of the web application? If not, you'll only be able to open it.
Not all web application templates are configurable. I assumed you were using the same template as the application you took a snapshot of, which is configurable.  When you create a template, the configurable ones have a little gear icon displayed over the thumbnail (see attached image). I'm guessing you're using one that can't be configured.
http://www.arcgis.com/home/group.html?owner=esri_fr&title=Web%20Application%20Templates
Mike
lionelQUIRIE
Thanks Mike,
I understand this notion of configurable model or not and I have chosen a configurate one "Visionneuse de base"
It's the same for all my old maps whitch I have insert a logo (see the link below for exemple), I can't see the configurate button and today I can't change this logo????
http://www.arcgisonline.com/apps/OnePane/basicviewer/index.html?appid=d23afa23ee0440e5af4727c19e3cfd...
The fact is that today I can't see the configurate button in all my maps old or new with the model "Visionneuse de base".
I have tested other configurable webmap models and I can configurate them but they don't propose logo field.
Thanks for your help.:confused:
Lionel
