Information lookup web app from AGOL
4235
7
08-07-2014 05:48 AM
ErikBlake
I have created a web app using the Information look up web app from AGOL. The map consistent of buffers around our water lines in their respected water service area. I want to use this app for the public to look up their address and see what service area they are in along with a pop-up with other information regarding their water source, how it is treated ect. However the search bar does not seem to want to work. when I type an address in it doesn't zoom. It just sits there. is this a known bug? Just wondering if anybody else experienced this. Or do I not have something configured right. I like this app and want to use it but if the search bar doesn't work going to have to find a different app. Any help would be great. Thanks.
MikeMillerGIS
Esri Frequent Contributor
Blake,
   You need to define the lookup layers when you config the app.  I will add an enhancement to trap the issue when no lookup layers are defined.
ErikBlake
Just to add to my question. When I perform a search in the web map that my application is based off it works fine.
MikeMillerGIS
Erik,
  Could you share your URL?  I would like to see what is going on.
Thanks
ErikBlake
Sorry I added it like three times. Don't know what I am doing on here yet.
MikeMillerGIS
Blake,
ErikBlake
So do I just add one or all my service areas in the look up. or do I need to add a parcels layer with addresses
ErikBlake
Never mind Mike I figured it out. Thanks for your help.
