Importing CSV with DMS Coordinates
5040
01-31-2022 01:39 PM
JessicaRouns
Currently, when importing a CSV the lat and longs need to be in decimal degrees. Does any one know of a way to import a CSV with lat and long in DMS? Using Pro is not an option. Are there any custom widgets that will aide this?
DanPatterson
MVP Esteemed Contributor
import your coordinates into excel and do the conversion there (dd = Deg + min/60 + sec/3600 )
For future reference Pro has this capability Coordinate Table To Point (Defense)—ArcGIS Pro | Documentation
but it doesn't appear to be in ArcMap's version
... sort of retired...
JessicaRouns
Hi Dan
This would be a bit of a last resort. Was hoping someone knew of a custom import widget specifically for DMS. The geometry service allows conversion between DD and DMS, wonder if something can be built utilising this service to publish DMS directly?
BryndaHatch
Jessica,
Have you tried ArcGIS for Office?  You can download it from here: https://www.esri.com/en-us/arcgis/products/arcgis-for-office/download
With ArcGIS for Office, I was able to plot DMS onto a map within Excel and then publish it to AGOL from there.  The only catch was that the Lat and Long had to be in separate columns.
https://doc.arcgis.com/en/office/install-and-configure/supported-notation-formats-m4o.htm
Brynda
JessicaRouns
Hi Brynda,
Thanks so much for the help doc. This is is a great quick fix solution, but the goal would still be a custom widget within Portal to read and spatialise DMS from a spreadsheet.
Thanks again,
Jess
BryndaHatch
Jess,
Since you're asking for a new feature, can I suggest you post your idea to the Ideas page? https://community.esri.com/t5/arcgis-online-ideas/idb-p/arcgis-online-ideas
The development team takes customer's ideas into consideration when planning new work.
Brynda
