Imagery Date
1821
09-08-2010 02:00 PM
RandallClark
How can i tell what the data of the aerial imagery used in bing maps is?
MikeMinami
Esri Notable Contributor
Esri doesn't have a way to get this... I found these things by searching...
According to this post, the only way to find the "vintage" is through their API.
http://www.bing.com/toolbox/forums/t/649533.aspx
If you can write some code, it seems like the GetImageryMetadata method may help.
http://msdn.microsoft.com/en-us/library/cc980893.aspx
A bit more information from ArcGIS forums...
http://forums.arcgis.com/threads/6610-getting-Bing-aerial-imagery-date
Bottom line is it seems you need to use their API to determine this. Wouldn't it be nice if they had an interactive application that did this?
Mike
ClemHenriksen
How do i get imagery vintage from AGO image services, such as the Imagery basemap?
MikeMinami
http://www.arcgis.com/features/maps/imagery.html
If you click on the map, you'll see the date the image was taken.
Mike
