Image hyperlinks
1200
08-14-2013 05:21 AM
JayKappy
Using a PERSONAL ArcGIS online account:
can I create a url in a field and have it hyperlink to a PDF and open that PDF via ArcGIS online personal account?
TimWitt
You can do it if the document is saved on a webserver, you can't if it is saved locally.
Here is an example of how to use hyperlinks.
http://blogs.esri.com/esri/arcgis/2012/10/04/url-parameters-in-pop-ups/
JayKappy
Thanks for the article...makes sense.
Assuming the personal ArcGIS online account consumes a Map Services that we provide from ArcServer
Would I store the images on that same server or would I need an external server to house the PDFs.
wondering how I would secure that?  I already have to login into ArcGIS online and then add another password to validate against the Map Service.
Any thoughts?
