Identify on embedded map
1186
08-18-2010 07:47 AM
ChrisMarsh
Is there any way to have the identify work on the embedded map?
When you save a map on Arcgis.com you can click the "Share" button and in that popup window there is some html code you can copy to embed the map into a webpage. in that code after the weblink there is code that says "zoom=true". This code adds the zoom-in and zoom-out buttons on the embedded map. Is there anyway to add identify to this code similar to the zoom function??
Any help would be greatly appreciated.
Chris
MikeMinami
Esri Notable Contributor
Unfortunately, there isn't a way to add identify functionality to the embedded map. I agree that it would be a useful feature.
Mike
ChrisMarsh
Mike,
Thanks for the info, I appreciate the quick response. I think the ArcGIS.com site and features are amazing. Lot of different ways it can be used.
Thanks again!
