I cannot import a shapefile to ArcGIS online.
3133
9
10-23-2018 10:25 AM
Anthony_Blate
I am having issues importing a shapefile to ArcGIS online.  Import fails and no error message is presented. I am also able to open the shapefile in other applications.
Please help.
Katie_Clark
MVP Regular Contributor
What workflow are you using? There's no error message, even if you look under Geoprocessing > Results > Current Session? It's hard to help you troubleshoot without more information...
Are you able to post the shapefile here?
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Anthony_Blate
See the attached images error
DanPatterson_Retired
are you doing this?  is it zipped?
Shapefiles—ArcGIS Online Help | ArcGIS
Anthony_Blate
Yes it is zipped.
https://www.arcgis.com/home/item.html?id=c8def7757a6c44528de966bc05a033d8
I think that I was able to add the shapefile, but I cannot visualize it.
by Anonymous User
Not applicable
I see you are adding the shapefile from the Map Viewer. Have you tried adding the zipped shapefile as an item from the content page?
Make sure you check the box to publish as a hosted layer when you upload it.
Anthony_Blate
The checkbox is not an option in my "Add an item from my computer" modal.
Anthony_Blate
Katie Cullen I attempted to email you with my contact info. Please let me know if you received it
by Anonymous User
Not applicable
I did not. You can send them to my email [email protected]
Anthony_Blate
Did you get my email today?
