Hyperlink in Popup bringing up garbage url
4060
09-28-2016 09:54 AM
StahlyEngineering
I've configured a popup for PLSS townships to show a hyperlink for an ftp server with files organized by township.
When I click the link in the AGOL map viewer on a desktop browser (chrome) the link works fine. If I click the link while viewing the map in a web app the link results in a garbage url and fails. When I test this on an android tablet neither the map viewer not the web app work.
I've following the following blog to create my link structure:
Using URL parameters in pop-ups | ArcGIS Blog
a typical url looks as such:
ftp://999.9.9.999/CORNER RECORDATIONS/T{township} R{range}
the garbage url adds the address of the map or app before the link and looks like this:
http://<organization>/apps/webappviewer/index.html?id=<app id>#999.9.9.999/CORNER RECORDATIONS/T{township} R{range}
Based on the blog comments this happened to other people as well, but the problem either disappeared magically or was given up on.
KellyGerrow
Esri Alum
Are you adding the html tag in the pop up?
There is a specific set of HTML tags and protocols that can be used in the ArcGIS Online website. Any tags/protocols, like FTP that aren't listed on this document will be filtered out when the web map is saved which may explain the url that you are reporting.
-Kelly
KellyGerrow
Esri Alum
-Kelly
Kara_Shindle
I just ran into this, and I was wondering if this was a organization security setting.  I am working in two AGOL accounts.  One is my own that I administer, and I have no problems with the pop up URLs, they work as they should.  The second AGOL account is for an organization and I am a user who can create web maps.  But creating a popup with a custom website URL results in it appending the organizations portal URL to the beginning of whatever website I have in my attributes.  Since I do not administer the second account, they are asking what setting they need to fix in order for the popup URLS to work properly.
Were you able to solve this?
StahlyEngineering
I ended up adding the link as an attribute to an image within the popup as a work-around.
Kara_Shindle
Just as a reply to my first comment, I ended up creating an Arcade expression to concatenate the Http:// protocol onto each web address, and it ended up working fine after that.
by Anonymous User
Not applicable
I had this question come to me and it turns out that the user was just putting in the "www.link.com" instead of "https://www.link.com" which was causing it not to be recognized as a proper link.
