How to Hyperlink to a Local HTML
5812
04-02-2015 10:47 AM
KevinHatch
I am trying to link a pop-up in ARC GIS Online to a locally hosted HTML document.  I have tried both of the following:
file:///C:\Users\khatch\test.html
file://localhost/C:\Users\khatch\test.html
If I manually put either of the above in my browser the document opens.  However. when I add that as an image link in the pop up (either in the pop up media or in the customer attribute editor) nothing happens when I click on the pop-up.  When I right click and open in a new tab I get "about:blank" in the address bar and nothing appears.
I have tried this in both Chrome and in IE.  Any suggestions?
JakeSkinner
Esri Esteemed Contributor
Kevin,
Do you have IIS enabled on your machine?  If so, you can copy the HTML file to you C:\inetpub\wwwroot directory.  You can then reference the HTML document using the following:
http://<machine name>/test.html
JakeSkinner
Kevin,
KevinHatch
They are stored on our file server. It looks like I will need to move them to a web server if I need to access them via an http link.  Thanks for the info.
