How to get the indices of items in an array using Arcade
2427
10-17-2021 06:04 AM
pat_algura
I have a hosted feature service with Attachments, and I want to create a list of indices of the attachments per feature. Ultimately, I want to get the position of each attachment per feature.
I used Array(Count(Attachments($feature)), which creates an array based on the number of attachment the feature has, but I'm stuck here. I'm new to Arcade and will appreciate any help!
JohannesLindner
var attachments = Attachments($feature)
var txt = []
for(var a in attachments){
    Push(txt, a+1)
return Concatenate(txt, ", ")
What's your end goal here? Because I fear it's linking those indices to the attachments. If so, you're on the wrong track.
Have a great day!
Johannes
SzuNyiapTang
Hi @pat_algura
Attachments($feature) will gives you the dictionary of the attachments per feature.
You can then loop through the dictionary to get the id.
var txt = ""
for(var attach in attachments){
    txt += (attachments[attach].id) + ","
return txt
Cheers,
Tang
Cheers,
Tang
pat_algura
Thanks for responding @SzuNyiapTang
This approach pulls the attachment ids though instead of indices.
For each element, I want it to show:
Attachment List
1,2,3,4,5
1,2,3,4
1,2,3,4
Patricia
JohannesLindner
var txt = []
    Push(txt, a+1)
Have a great day!
Johannes
pat_algura
Thank you! This is exactly what I'm trying to achieve 😄
Cheers,
Patricia
