Hello ,
will be possible to create one App but this app as a window for different apps that I have designed and each icon for each app connect to his specific url .
I mean ,when I open this app ,I have icons and when I click on each icon ,it should open this url that belong to this app .
so my target : one app includes different icons for different apps that I have designed .
Thanks in advance .
Take a look at the Experience Builder.
I made this quick (and ugly) example in 5 minutes:
So basically, use a Section widget. For each app you want to include, make a new View in the section widget adn create an Embed widget pointing to the app's URL.
Create the top bar using a Row widget, insert a Text widget for the tile, and a View Navigation widget for switching between the apps.
I agree Experience Builder is the way to go. If you want more of a 'landing page' look for your start page, you can give each app their own page using the embed widget and a home page with images, links, or icons to navigate.
I would then include a header on all of your app pages with a menu for easy navigation between apps.
Thanks , I will try to use Experience Builder
Thanks a lot
Experience Builder is a great option! Another alternative that could be worth looking into is the Category Gallery Instant Apps. Here is an example application: National Parks Data Gallery (arcgis.com)
Sounds like you are describing a Hub site similar to:
https://richland-hub---gis-mapping-richlandwa.hub.arcgis.com/
R_
That exactly what I want ,thanks to mention in it .
Could I build the same by Experience builder ?or what should i look for ?
Another option might be the Portfolio instant app. You can view a gallery of examples here: https://doc.arcgis.com/en/instant-apps/gallery/?categories=%2Fcategories%2Ftemplates%2Fportfolio
And learn more about the capabilities here:
